2023-01-30 8:57 AM
2023-01-30 9:09 AM
If both sets of values lie within the allowed range (including the VCO max frequency) - there is not a big difference. Higher VCO freq will result in higher power consumption by PLL.
2023-01-30 9:27 AM
Depends where the sweet-spot is for the PLL comparison frequency. For the F2/F4 I think it was suggested in the 1-2 MHz region.
Also the VCO likely has a preferred operating range, ie 100 - 432 MHz.
Check the DM and RM
Typically you divide down the VCO frequency to get a square wave into the MCU
