2012-07-12 3:53 AM
i have connected the usb hub to the discovery board using micro usb port...now i connected a pen drive 1 to the one port on hub...i want to do is when i connect another pen drive to the 2nd port on hub...the ucontroller will detect it and copy all the data from pendrive 1 to pendrive 2...so is it possible to do on discovery board??? if yes how,,
2012-07-12 1:00 PM
You might want to investigate if the part can host it that fashion, my understanding is that it isn't a full host implementation, and if you need a commercial USB stack.
