2014-10-31 12:02 PM
As soon as the USB disk is connected, I get an assertion fail, with this comment above this assertion:
/* The following assertion will fail if a service routine (ISR) for
an interrupt that has been assigned a priority above configMAX_SYSCALL_INTERRUPT_PRIORITY calls an ISR safe FreeRTOS API function. ISR safe FreeRTOS API functions must *only* be called from interrupts that have been assigned a priority at or below configMAX_SYSCALL_INTERRUPT_PRIORITY.*/configASSERT( ucCurrentPriority >= ucMaxSysCallPriority );
I tried to change the OTG_FS_IRQn priority as follows:HAL_NVIC_SetPriority(OTG_FS_IRQn, configMAX_SYSCALL_INTERRUPT_PRIORITY+1, 0);
But this did not make any change.I found this happand just as soon as this is called:osMessagePut ( phost->os_event, USBH_PORT_EVENT, 0);
Any ideas how to fix this?Thanks2014-11-02 11:01 PM
problem solved by help from FreeRTOS forum:
HAL_NVIC_SetPriority(OTG_FS_IRQn, configLIBRARY_MAX_SYSCALL_INTERRUPT_PRIORITY , 0);
