2011-05-07 3:38 AM
Timer External Clock
2011-05-17 5:34 AM
dont waste your time trying to count ETR pulses
no matter what I tried I couldnot count ETR pulses There must be a hardware bug try counting CH1 pulses instead2011-05-17 5:34 AM
The reason for not counting was a cold solder junction at the enameled copper wire what does the modification of PCB from T2-CH4 to T3_ETR pin. As soon as there is a signal with edges at the ETR pin, the above posted code increments the counter like expected. >no matter what I tried I couldnot count ETR pulses Try the code from above and check your ETR pin for present pulses. If they are missing, there must be a hardware bug...We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
