2020-10-29 11:06 PM
I was coding with nucleo f401re board in stm32cubeide. However, I found a problem with timer not working properly when iwdg is enabled in ioc settings. Do you know a solution to this?
2020-10-29 11:32 PM
The IWDG should have no effect on the timers unless the watchdog causes a reset, in which case the timers, along with almost everything else, will be reset. What problem are you seeing?
2020-10-29 11:42 PM
Regardless of the prescaler and period values that I have set, the time value created by the timer is displayed at will.
2020-10-30 6:48 AM
How are you determining the timer value is wrong? Can you post a minimal working example showing the problem?
