2009-07-12 11:55 AM
T6963
2011-05-17 3:42 AM
Dear jj.sprague,
I'm just trying to follow your directives but i often get stuck. Here is my init code and cls code : void abg_init(void) { int i; ABG_DATA_TRIS(Out); ABG_CTRL_TRIS(Out); // release reset signal bitset(ABG_CTRL_PORT, ABG_RST); bitclr(ABG_CTRL_PORT, ABG_RST); for (i = 0; i for (i = 0; i bitset(ABG_CTRL_PORT, ABG_RST); WriteData (0x00); WriteData (0x00); WriteCommand (0x40); WriteData (0x00); WriteData (0x00); WriteCommand (0x42); WriteData (30); WriteData (0x00); WriteCommand (0x41); WriteData (30); WriteData (0x00); WriteCommand (0x43); WriteCommand (0x81); // WriteCommand (0x88); WriteData (0x00); WriteData (0x00); WriteCommand (0x22); } void abg_clrscr(void) { unsigned short i; WriteCommand(0x98); // Set 10011000, Text off graphic on // Setting address area for graphic mode WriteData (0x00); // Send low adrs WriteData (0x00); // Send high adrs WriteCommand(0x24); // Send command set address pointer for (i=0; i< 3840; i++) { WriteData(0x00); // Clear screen WriteCommand(0xc0); // Send command data write } } I'm **really really** bored and could not trace. You're experienced, could you please track my code? Here is the ''clear screen'' result : http://img604.imageshack.us/content.php?page=blogpost&files=img31/9906/glcd.jpg I see ''vertical'' lines :( I read datasheet many times, examined a lot of codes and still no result.. Optizyme [ This message was edited by: optizyme on 07-07-2009 23:13 ]2011-05-17 3:42 AM
Prefer to provide general strategies - enables ''you'' to experience the joy of problem solving/mastery.
Have you followed the list - specifically have you placed T6963/clone into character mode - and can you then ''cls'' and place desired chars anywhere on screen? If not - we are approaching the state of ''maximum randomness'' - which will delay and frustrate you/me/other forum readers. We have not yet established that your data-bus and control signals are both hardware and timing appropriate. Attempting the more complicated graphic mode ''first'' - before mastering text, addressing and ''cls'' adds undue complication. (ask that you accept my 25 yr. experience w/Lcds) Vertical lines are not good - usually indicate improper initialization (or worse - ''no'' initialization - and if you're really unlucky indicate that you have ''blown'' a column driver). There are brighter/more able ''helpers'' on this forum. I ''need'' you to follow procedures exactly - in sequence - and report results. Your reporting does not enable me to help you - for instance we have ''no idea'' how you eventually got the dot-field to reveal. Did you try to display the simpler text only? Results? I don't like the initialization listing - appears that you are sending data before the governing command. Its been 15+ years but I recall somewhere around 6-8 ''initialization commands'' required by T6963. Peek at your listing shows too few. (I don't have data - nor access - nor enough free time to gather all of this for you) Have a sure-fire means to cure your boredom - try running a small business in these times - keeping employees, clients, vendors all happy - while providing tech assistance...2011-05-17 3:42 AM
Dear jj.sprague,
I would like to thank you for your effort. After fighting many time, i sent e-mails to manufacturer company and they sent me new schematic. In datasheet PD pin wasn't connected but in schematic it is connected. When i connect it to VDD, my lcd started to work :) Here is the source code : http://rapidshare.com/files/255124290/SAP1024B.rar You are great person, i again thank you :) optizyme2018-08-21 12:33 AM
I try to use this LCD but i don't find any example code..
Can you send me your source code by mail ? because i can open your. (mail : qanaelle@orange.fr)
Please :)
Best regards,
Anaelle
2018-08-21 3:19 AM
If you haven't noticed - this exchange is seven years old. The posters are hardly present here anymore.
You may find "jj.sprague" on the TI Cortex M forum (frequent poster there), don't remember his nickname there.
And try to drop "STM32" from the list of search terms when looking for example code.
