2018-02-11 10:03 PM
Hi all,
I want to enable touch sensing in L151. I used Cube to configure and when I go to configuration tab and click on TS, I get a pop-up showing 'Cube does not support configuration of this IP mode. You can configure it manually'. I would like guidance/tutorial on how I can configure touch and make it work. Thanks in advance for your help and support.
#l151-touchWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
