2014-12-16 6:58 AM
hi everybody,
as far as i understood the data in the RTC registers are lost after a hardware reset or the power is lost. So the next idea is to use a battery as a backup. But after reading the data sheet and reference manual i can't find a pin on the STM32L051 to connect to a battery. Can someone confirm this? Are there any other possibilities to keep the RTC data? #stm32l0 #rtc #battery-backup2014-12-16 8:03 AM
Can't say I've spent any time on the L0, but the L1 was similar, it was expected to be battery powered. You could use a
https://www.fairchildsemi.com/datasheets/BA/BAV70.pdf
on the supply to use the primary or battery supply.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
