2018-08-30 3:01 AM
I am trying to use the STM32l011k4 with the Sharp memory display breakout from Adafruit. I succeeded in clearing the screen but I can't display a pixel on the screen. I always have the same display, probably what the buffer contains. I don't know if the problem comes from the clock or the SPI communication but I think the write in the buffer is fine. I am using Keil IDE. Did someone already try to put together these devices ? Thank you for your help.
Best regards
