2022-10-24 12:15 AM
Need your advice.
PCB routing. I have Divided signals into 4 groups + (CLK) :
1: Address: SDRAM_BA[0-1]/SDRAM_A[0-11]
2: Command: SDNRAS/SDNCAS/SDNWE
3: Control: NE0/CKE0/NBL[0-1]
4: Data: SDRAM_D[0-7] ( sub goup1 ) & [8-15] ( sub group 2)
5: SDCLK
I'm not sure about DQM ( output byte mask for the write access (DQM).) should this belong to data pair(s) or Control pair? According to ST it is Control goup. According to Miron TN-46-14 it is data group?
Thanks
Thanks
2022-10-26 1:38 AM
Hi
DQM is a part of data pair. If you want use them, DQM should be data group and match length with correspond data signals.
