2020-12-14 2:21 AM
Hi Folks,
Greetings !
With a Nucleo-G474RE MB1367C, with an onboard 32.768kHz crystal:
I am trying to turn ON the LSE oscillator, but the LSE oscillator does not get RDY at all.
This is what I tried to do:
void SystemClock_Config(void)
LL_FLASH_SetLatency(LL_FLASH_LATENCY_4);
#if 0
/* Enable boost mode to be able to reach 170MHz */
LL_PWR_EnableRange1BoostMode();
#endif
LL_RCC_HSI_Enable();
while (LL_RCC_HSI_IsReady() != 1) {};
LL_RCC_HSE_Enable();
while (LL_RCC_HSE_IsReady() != 1) {};
#if 0
LL_RCC_LSE_SetDriveCapability(LL_RCC_LSEDRIVE_MEDIUMHIGH);
LL_RCC_LSE_Enable();
// LL_RCC_LSE_EnableCSS();
while (LL_RCC_LSE_IsReady() != 1) {};
#endif
/* Main PLL configuration and activation */
LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_6, 85, LL_RCC_PLLR_DIV_2);
LL_RCC_PLL_Enable();
LL_RCC_PLL_EnableDomain_SYS();
while (LL_RCC_PLL_IsReady() != 1) {};
/* Sysclk activation on the main PLL */
LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_2);
LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
while (LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL) {};
LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
/* Insure 1µs transition state at intermediate medium speed clock based on DWT */
CoreDebug->DEMCR |= CoreDebug_DEMCR_TRCENA_Msk;
DWT->CTRL |= DWT_CTRL_CYCCNTENA_Msk;
while (DWT->CYCCNT < 100);
LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
LL_Init1msTick(170000000);
LL_SetSystemCoreClock(170000000);
LL_RCC_SetUSARTClockSource(LL_RCC_USART2_CLKSOURCE_PCLK1);
}Any thoughts, what I am missing ?
Thanks,
Manu
2020-12-14 10:38 AM
In your example, enabling LSE is commented out, so it never happens. LSE getting stable so that LSE_READY gets set can take considerable time. Enable is early, do the rest of the initialization beside things requireing LSE , wait for LSE and do the rest.
2020-12-14 10:46 AM
Hi Uwe,
I've commented it out to make sure that the rest of the code runs.
In the test case that I am able to successfully run, it does not have the #if 0.
The #if 0 was put in to avoid the indefinite loop with "while (LL_RCC_LSE_IsReady() != 1) {};"
Just to make doubly sure that the it is looping for "LSE_IsReady".
Any other thing that comes to your mind ?
Thanks,
Manu
2020-12-14 10:55 AM
I can say for sure, however long I wait, LSE_RDY does not happen.
Verified the same, with this:
LL_mDelay(1000);
LL_mDelay(1000);
LL_mDelay(1000);
// LSE RDY does not occur!
}Thanks,
Manu
2021-01-19 9:47 AM
Finally, solved the problem!
Just before doing a LSE enable, enabling backup access, with a forced backup domain reset/release did solve the problem.
Just for completion sake ..
Cheers,
Manu
