2026-03-04 11:45 PM
Same issue reported in 2020: https://community.st.com/t5/stm32-mcus-products/stm32g473-fdcan-pinout-contradicting/td-p/224770.
As of DS12712 Rev 5, Table 13 Alternate Functions has PB10 and PB11 mis-labeled as FDCAN3_RX and FDCAN3_TX respectively.
Under AF11, PB10 and PB11 are not available as FDCAN3_RX and FDCAN3_TX.
2026-03-05 1:51 AM
I am confirming that there is mistake in Table 13. Alternate function : the PB10/PB11 shoud not have FDCAN functionality. this mistake will be corrected in next datasheet revision.
"Table 12. STM32G473xB/xC/xE pin definition" is correct - there is no FDCAN functionality for PB10/PB11.
Igor
2026-03-04 11:48 PM
I will check and get back to you.
2026-03-05 1:51 AM
Igor
2026-03-05 2:42 AM
Internal ticket for follow-up/fix 228414
