2024-06-12 4:28 AM - last edited on 2024-06-12 4:33 AM by mƎALLEm
hello,
sd card write on f469 discovery is working. and now referring to msc_standalone example (which works alone), usbd_storage_if.c file is matched and usb mass storage selected from MX tool.
But i cant see the drive coming. can i know steps have msc_standalone for MX generated code.
2024-06-12 5:44 AM
Hi @GauravK
Could you share your project from github link or attach it to discussion? Did you succeed to enumerate it as mass storage device using this project?
2024-06-12 7:01 AM
project is working. can see drive having sd card data.
My tried project is attached. would be helpful to know the mistake.
2024-06-24 9:15 PM - edited 2024-06-24 11:37 PM
Hello, I got USB FS for MSC on board working for F439 Nucleo. Now try is for USB3300 HS with Waveshare board.
I configured through MX and updated usbd_storage_if similar to FS changes. But I dont see USB getting detected in Windows.
Is this driver issue or code issue? (Tried installing mentioned driver for USB3300).
VCP driver looks to be not for Windows 10.
CDC_Control(), I could find as suggested in net..since I want USB MSC
