2014-06-17 4:45 AM
Hello everyone. I am creating a hexapod with 18 independent servos, using 18 channels on General - Purpose timers. I have problem with few timers, simply servo is not responding to new compare value. I am using timers:
TIM2 - 4 channels working TIM3 - 4 channels working TIM4 - 4 channels working TIM5 - chanel 2 and 3 not working TIM12 - not working Do I have some conflicts with alternative configuration ? My init for timers/pwm:
void initTimer()
RCC_TIMCLKPresConfig(RCC_TIMPrescActivated);
/* TIM2 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
/* TIM3 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
/* TIM4 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
/* TIM5 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM5, ENABLE);
/* TIM12 clock enable */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM12, ENABLE);
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
/* Compute the prescaler value */
uint16_t u16PrescalerValue = (uint16_t) ((SystemCoreClock) / 1000000)- 1;
TIM_TimeBaseStructure.TIM_Prescaler = u16PrescalerValue; // 1MHz
TIM_TimeBaseStructure.TIM_Period = 20000 - 1; // 1 MHz / 20000 = 50 Hz (20ms)
TIM_TimeBaseStructure.TIM_ClockDivision = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
TIM_TimeBaseInit(TIM12, &TIM_TimeBaseStructure);
void initPWM()
* Servo min(1ms) = 1000
* Servo neutral (1,5ms) = 1500
* Servo max(2ms) = 2000
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 0;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
/*********************TIM2**************************/
/* PWM1 Mode configuration: Channel1 (GPIOA Pin 15)*/
TIM_OC1Init(TIM2, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOB Pin 3)*/
TIM_OC2Init(TIM2, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel3 (GPIOB Pin 10)*/
TIM_OC3Init(TIM2, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel4 (GPIOB Pin 11)*/
TIM_OC4Init(TIM2, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Enable );
/*********************TIM3**************************/
/* PWM1 Mode configuration: Channel1 (GPIOB Pin 4)*/
TIM_OC1Init(TIM3, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOB Pin 5)*/
TIM_OC2Init(TIM3, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel3 (GPIOB Pin 0)*/
TIM_OC3Init(TIM3, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel4 (GPIOB Pin 1)*/
TIM_OC4Init(TIM3, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable );
/*********************TIM4**************************/
/* PWM1 Mode configuration: Channel1 (GPIOD Pin 12)*/
TIM_OC1Init(TIM4, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOD Pin 13)*/
TIM_OC2Init(TIM4, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM4, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel3 (GPIOD Pin 14)*/
TIM_OC3Init(TIM4, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel4 (GPIOD Pin 15)*/
TIM_OC4Init(TIM4, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable );
/*********************TIM5**************************/
/* PWM1 Mode configuration: Channel1 (GPIOA Pin 0)*/
TIM_OC1Init(TIM5, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM5, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOA Pin 1)*/
TIM_OC2Init(TIM5, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM5, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel3 (GPIOA Pin 2)*/
TIM_OC3Init(TIM5, &TIM_OCInitStructure);
TIM_OC3PreloadConfig(TIM5, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel4 (GPIOA Pin 3)*/
TIM_OC4Init(TIM5, &TIM_OCInitStructure);
TIM_OC4PreloadConfig(TIM5, TIM_OCPreload_Enable );
/*********************TIM12*************************/
/* PWM1 Mode configuration: Channel1 (GPIOB Pin 14)*/
TIM_OC1Init(TIM12, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM12, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOB Pin 15)*/
TIM_OC2Init(TIM12, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM12, TIM_OCPreload_Enable );
/*********************TIM9*************************/
/* PWM1 Mode configuration: Channel1 (GPIOE Pin 5)*/
TIM_OC1Init(TIM9, &TIM_OCInitStructure);
TIM_OC1PreloadConfig(TIM9, TIM_OCPreload_Enable );
/* PWM1 Mode configuration: Channel2 (GPIOE Pin 6)*/
TIM_OC2Init(TIM9, &TIM_OCInitStructure);
TIM_OC2PreloadConfig(TIM9, TIM_OCPreload_Enable );
//enable timers
TIM_Cmd(TIM2, ENABLE);
TIM_Cmd(TIM3, ENABLE);
TIM_Cmd(TIM4, ENABLE);
TIM_Cmd(TIM5, ENABLE);
TIM_Cmd(TIM9, ENABLE);
TIM_Cmd(TIM12, ENABLE);
void initServos()
GPIO_InitTypeDef GPIO_PWM;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOE, ENABLE);
GPIO_PWM.GPIO_Mode = GPIO_Mode_AF;
GPIO_PWM.GPIO_Speed = GPIO_Speed_100MHz;
GPIO_PWM.GPIO_OType = GPIO_OType_PP;
GPIO_PWM.GPIO_PuPd = GPIO_PuPd_UP;
//PORT A
GPIO_PWM.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_15;
GPIO_Init(GPIOA, &GPIO_PWM);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_TIM5 );
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_TIM5 );
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_TIM5 );
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_TIM5 );
GPIO_PinAFConfig(GPIOA, GPIO_PinSource15,GPIO_AF_TIM2 );
//PORT B
GPIO_PWM.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOB, &GPIO_PWM);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_TIM3 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_TIM3 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource3, GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource4, GPIO_AF_TIM3 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource5, GPIO_AF_TIM3 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10,GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11,GPIO_AF_TIM2 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_TIM12 );
GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_TIM12 );
//PORT D
GPIO_PWM.GPIO_Pin = GPIO_Pin_12 | GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOD, &GPIO_PWM);
GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource13, GPIO_AF_TIM4 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource14, GPIO_AF_TIM4 );
GPIO_PinAFConfig(GPIOD, GPIO_PinSource15, GPIO_AF_TIM4 );
#pwm #stm32f4 #discovery #output
2014-06-17 10:57 PM
It might be this, but how can I get rid of this conflict? This is not enough?:4
///////////////GPIO CONFIGURATION///////////////
GPIO_PWM.GPIO_Speed = GPIO_Speed_50MHz;
//PORT A
GPIO_PWM.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
2014-06-18 4:21 AM
Think about this for a second, how does reconfiguring the STM32 change the behaviour of pins driven by external devices? Your options sometimes come down to removing devices or cutting traces.2014-06-19 2:14 AM
So I can't use pins which can used as TIM5 even if in datasheet there is info that PA1 PA2 are alternatively TIM5?
2014-06-19 5:45 AM
Could you please help me with TIM5? I really need this timer working
2014-06-19 7:24 AM
Look I don't have magic powers, does it work if you remove the other part? Can you use some other pins/timers to get what you need? TIM1_CH1 PA8, TIM1_CH2 PA9, TIM1_CH3 PA10, TIM1_CH4 PA112014-06-19 7:28 AM
YOU HAVE AN EXTERNAL DEVICE DRIVING VOLTAGE INTO THE PINS, REMOVE U3 AND TRY YOUR EXPERIMENT AGAINWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
