2016-03-10 12:28 AM
Greetings,
This will probably be an amateur question for most of you but I need to make sure.I have a project in which I use an stm32F407VGT6 mcu and I need to make another board.I don't have access to those mcus anymore, however, I have access to the stm32F407VEvariant. My question is: Can I just put in a VE variant instead of the VG and expect it to work?I looked in the datasheet in page 13/14 it shows the table with the VG and Vxx and it looks like the difference is only in the flash 1024/512 and camera interface. Am I interpreting it correctly?Thanks in advance2016-03-14 8:48 AM
Hi heizenberg.shagas,
Your interpretation is correct.Refer to the page 184 ofhttp://www.st.com/web/en/resource/technical/document/datasheet/DM00037051.pdf
to get more details on the part numbering.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
