2016-08-17 11:06 AM
I currently have a 3.3V PWM on TIM3_Channel2.Can the output be changed to a 5V logic?Sel2016-08-17 11:43 AM
It depends on what you are driving.
You should probably consider using a buffer that can do the level conversion.You can configure the pin in open-drain mode, and have a pull-up resistor to 5V on pins that are FT (Five volt Tolerant) per data sheet.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
