2014-08-07 1:24 AM
Hello ST,
I have found a discrepancy between the documentation of the STM32F2x MCU and the STM32Cube as well as the StdPeriph implemenation.On page 656 of the RM (RM0033_CD00225773, DocID15403 Rev 6) it is said that bits 31:9 of the UART DR have to be kept at reset value. However, both STM32Cube and StdPeriph libraries set these bits to 0 at transmit/send.Does someone from ST can clarify, please.Best regards,sphere #stm32-documentation2014-08-07 10:40 AM
I'm not from ST but I think you overinterpreted it.
DR should just be written the data to be transmitted, writing a value higher than 0x1ff doesn't make any sense so bits 31:9 are kind of reserved.2014-08-07 11:55 AM
This is a PAIR of registers, not memory cell, the register you read is a holding register for in-bound data, the register you write is a different out-bound register. You can't read the out-bound register.
