2011-07-10 1:56 PM
2011-07-11 1:16 AM
copy teh attached file at the following path and see if teh warnings are removed.
C:\Program Files\IAR Systems\Embedded Workbench 6.0\arm\inc\c
________________ Attachments : intrinsics.h : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Hzgv&d=%2Fa%2F0X0000000beT%2FpsOj20vkB29P3xt.dVEWf3.YiATIA6ko5Ub5N.gKHj0&asPdf=false2011-07-11 7:54 AM
I already have revision 43377 of intrinsics.h at that location. Your revision is 34635. Is there some reason to change to your revision ?
My standard peripheral library version is 3.1.2. The ST web site now has version 3.5.0, and it also has the duplicate #defines. Since only a warning is produced, the code may execute OK, but even warnings should be fixed. ST-One - what say you ?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
