2013-06-11 12:52 AM
2013-06-11 6:49 AM
Make sure you have a short length of twisted-pair wire between the two transceivers, about 10cm, and that you have a 120 ohm termination resistor on both ends of the cable.
Check with a scope that you are seeing data coming out of the transceiver, differential pair has one line hi and the other low. Jack PeacockWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
