2018-08-17 1:43 AM
when we debug and compile in ST-Link/V2 by IAR IDE in STSPIN32f0 then this shows a problen that fatal error no MCU find. so what should be do for remove this error
2018-08-17 2:28 AM
Hello @supad ,
I recommend you to upgrade firmware version using STM32 ST-LINK Utility: go to ST-LINK>firmware update. Then, disconnect and connect your board.
And check the jumper position.
With Regards,
Imen
