2025-08-26 10:28 PM
I am working STSPIN32F0 and I have STVAL-SPIN3201 evaluation bord and install Motor Control WorkBench 6.4.1.
When I try to generate project, it is given "STM32CubeMX not found - ver. "6.0.0" or higher is required" error but CubeIde 1.19.0 was install in my computer nevertheless I install cubemx 6.15.0 but problem to continue.
How can solve this problem?
2025-08-26 11:51 PM
thanks,
I have solve problem. I install motor control workbench same folder and change my computer language English.
Now it is working.
Best Regards
2025-08-26 11:23 PM - edited 2025-08-26 11:23 PM
Hello @InovensoElectronics,
Could you review this post?
According to the latest responses, if the tool installation is performed using the Turkish language, it might prevent the path from being set correctly.
If this is the case, could you reinstall the tool using the English language?
2025-08-26 11:51 PM
thanks,
Now it is working.
Best Regards
2025-10-23 12:31 AM
Hai,
I am also facing the same issue. SAME FOLDER - What is it? CubeIDE?
Jayaraj.A
2025-10-23 1:53 AM
I have changed my computer language from original to English to comlpetly.
Now is working.
2025-10-23 2:19 AM
Ok Thanks. English (United Kingdom) - It is showing in Windows11 pro. I am from India. How it has to be?
