2016-08-08 5:14 AM
2016-08-08 6:23 AM
Is that the maximum speed
It's is constrained by the resolution and the bandwidth of the bus. Compute the data rate over the bus based on your clocks, and configuration. Use a scope or logic analyzer to confirm the bus performance.Then ask yourselfWhat is the application?What FPS your application needs?How much data would that rate generate per second?What is the ceiling on the data rate defined by the bus?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
