2023-03-02 7:27 AM
2023-03-02 3:47 PM
For full USB compatibility, the hardware interface and your device firmware should be made correctly.
Windows 10/11 seems to be more picky about compliance with standards.
Try Linux on same or similar PC, if it won't behave better, then likely there's a hardware issue. Otherwise, look at the software (timing, format of descriptors...).
Sometimes a hub (such as in your docking station) can 'fix' electrical issues and make the device look good to the host.
2023-03-13 8:09 AM
Thank you! Doing a mix of that has made it successfully connect.
