2011-10-15 1:03 AM
I could not simulate my code written for STM32F205ZE using keil 4.2V.Following is error code it is showing, when I start debug session.
*** error 65: access violation at 0x0000000C : no 'read' permissionIf I try to run it is showing:*** error 65: access violation at 0x00000000 : no 'execute/read' permissionPlease give me suggestions to solve this problem.2011-10-15 8:53 AM
http://www.keil.com/support/docs/814.htm Try reviewing documentation Try Keil technical support Try using the most current release (v4.22 last I checked)
2012-05-31 7:51 AM
I have the same problem, and cost about 6 hours screwing around ''trying'' stuff, still doesn't work...
Never had a problem with NXP, now I will be ''trying'' a different line of processors!2012-05-31 8:19 AM
But ST isn't responsible for the failings of KEIL software.
KEIL does not represent that the part is simulated.http://www.keil.com/dd/chip/5110.htm
ST has eval boards in the $10-20 range that permit testing on a physical part. Simulators classically fail to represent the nuances of the silicon implementation accurately.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
