2017-09-14 4:55 AM
My question is regarding RS485 Modbus protocol I am using STM32F030 Nucleo board for communication with RS485 board two USART is used (USART1 AND usart2) for communication purpose I am sending data USART2 (ST-KIT) to USART1 (laptop)one GPIO pin is used for driver/receiver enable when GPIO pin is high data will transmit and when it is low then data will receive I am fresher and unable to write code so please guide me with example
2017-09-14 5:20 AM
I'm not sure someone who's unable to write code can successfully write a microcontroller project without reading tons of books and documentation first, but if you insist.. then straight to examples: download the STM32CubeMX software, install the STM32CubeF0 libraries ('Help->Install New Libraries'), find your repository's folder in 'Help->Updater Settings', there you will find many example projects.
By the way, STM32F030's USARTs have hardware flow control for RS485, read the reference manual.
2017-09-14 8:16 AM
This is the job of your teacher, tutor or supervisor, have higher standards and hold them accountable. Professional guidance is expensive.
