2024-11-02 8:01 PM
I'm working on various examples using rider7. However, sometimes I encounter unexplained errors. The issue is that the hex file doesn't change. It seems like there might be garbage values in the hex file, as nothing works. Even if I change the main.c file multiple times, it keeps generating the same hex file. What could be the problem?
2024-11-03 1:13 AM
And what is rider7 ?
2024-11-03 1:28 AM
I missed. It's ride 7 not rider 7.
2024-11-03 10:45 PM
@sa11 Well, that sounds like an issue with the tool from Raisonance, maybe you find some support at their website?
Good luck!
/Peter
