2009-08-30 10:43 PM
Ride 7 RKit and ST library temple problem
2011-05-17 4:21 AM
2011-05-17 4:21 AM
Hi robinsm,
Could you check that you have the right and latest version of Ride7, Here is my version and it working fine. Hoe this helps you. Cheers, STOne-32. [ This message was edited by: STOne-32 on 26-08-2009 22:01 ] [ This message was edited by: STOne-32 on 26-08-2009 22:02 ]2011-05-17 4:21 AM
I have newer versions.
2011-05-17 4:21 AM
The template that comes with RIDE7 works fine (compiles okay), but the one in the new library (3.1.0) does not.
2011-05-17 4:21 AM
I did a fresh install of everything, and still no luck.
2011-05-17 4:21 AM
I will use the default template until the issues with the new library are resolved.
2011-05-17 4:21 AM
Hi robinsm,
It seems a Ride7 tool-chain limitation in the latest version and for sure would be fixed in a new version from Raisonance, You can post you message here : http://raisonance-forum.xsalto.com/index.php Cheers, STOne-32.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
