2023-07-24 1:30 AM
Hi community.
I would like to know if reading the internal temp of the mcu (using the right channel of the adc) can give you an accurate idea of the temperature of the pcb where the mcu is mounted.
Is it accurate this temp?
Is it sensistive to other effects ?
Does it work to use this information?
Thanks a lot for your reply
2023-08-22 3:25 PM
Probably pretty awful.
Used TMP116 (1/128 C resolution) and BMI160 (1/512 C resolution) devices here. Many IMU type devices have temperature sensors
2023-08-22 2:17 PM
Dear @SGasp.1 ,
This application note may interest you :
https://www.st.com/resource/en/application_note/an5036-thermal-management-guidelines-for-stm32-applications-stmicroelectronics.pdf
you can read Tj ( jonction die ) temperature and then using the data inside the Datasheet you may estimate board temperature if you have models of your PCB for thermal study.
hope it helps you .
Ciao
STOne-32
2023-08-22 3:25 PM
