2018-12-26 6:11 AM
2018-12-26 6:31 AM
NAND has page/block structure (for read), not a uniform contiguous address space like NOR flash, hence: NO.
BTW: Why would one want to use NAND flash for that?
2018-12-26 6:33 AM
Most are NOR. Check the flash data sheet to see if it supports the simple command and random addressing that would be needed.
2018-12-26 6:51 AM
Andreas, thank you very much.
NAND flash is much cheaper than NOR, so it would be much more attractive for using.
Best regards,
Vadim Aleynikov
