2010-11-24 2:59 AM
PortB Pin 8 not pulling down
2011-05-17 5:16 AM
More likely you have some thing external driving PB.8, the pull up/down is going to be pretty weak.
Set the pin floating and scope it.2011-05-17 5:16 AM
Hi clive,
Thanks for your answer. I have checked the connection. It looks like it's stuck at high. I didn't find anything that is wrong with the PCB trace. Do you think I can add an external pull down resistor to this pin to put it down? VictorWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
