2024-09-07 5:05 AM
Good Afternoon Sir/Mam,
We are Engineering Students. We have a PCB Design and I want to get it manufactured. We want it's single piece for our Prototype Development and Testing, once our Prototype completes the requirement criteria, we will order it in bulk.
So, it would be very helpful if you could tell us, if you also manufactures the customized PCB.
Thanking You,
ANKUR.
2024-09-07 5:19 AM
Hello @Ankur_1
ST Microelectronics does not manufacture Customized PCB. For more details about what we do, please take a look to our website .
Best Regards.
STTwo-32
2024-09-07 5:19 AM
Hello @Ankur_1
Best Regards.
STTwo-32
2024-09-07 6:19 AM
2024-09-07 6:36 AM
Making one piece is typically uneconomical, buy a board and fab yourself.
Setup costs likely make 3 to 5 units at least tenable. Figure out what threshold is for your design.
Or proof your design via a mashup of available boards as a proxy of the final one in areas where you are unsure.
Probably a couple.of board houses that can do short/limited run prototypes.
