2016-11-21 6:39 AM
Is there somewhere I can obtain older versions of cubeMX and the cube firmware libraries?since ST doesn't seem to maintain backward compatibility, I need cubeMX v4.14.0 and the stm32f4 cube library v1.11.0Thanks2016-11-21 6:49 AM
It's recommended to use the recently version of CubeMx/Firmware which contains bug fixes and enhancement. It's not possible to obtain older versions of CubeMX. But, it's possible for cube firmware libraries to install older versions from STM32CubeMx tool: Help > Install New libraries (you find all Cube releases)Regards2016-11-21 8:13 AM
Hi
Thank you for your response. The download from CubeMX does not work, I get and error at the end of download (see screenshot) installing 'From Local' works fine, i'm using v4.0 Thanks ________________ Attachments : Capture.PNG : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtmV&d=%2Fa%2F0X0000000aWp%2FB75UIbMigNSUxp3kP911hHkcGzoe8QTCqjQ4aQy_H5k&asPdf=false2016-11-21 8:19 AM
This is a mirror of
https://drive.google.com/open?id=0B7OY5pub_GfIMmFkblJIRUhSd0U
