2022-03-10 12:09 AM - last edited on 2025-02-12 1:17 AM by Andrew Neil
If a MCU is packaged in a MBB, is it then necessary to put the MBB in a climate controlled cabinet in between usage? If what is the recommendation of when to put in, how many days, weeks or maybe months can be accepted before the need of a cabinet?
2022-03-11 7:32 AM
Unopened? From experience, months should be fine. But it ultimately depends on the environment.
Not sure what you mean by "in between usage". It sounds like you're opening the package.
See:
