2012-05-28 9:28 AM
I have been using the Atollic (Lite) for my development.
My Atollic Projects work great (doing USB & MMC work). But I have run out of space with the 32K limit. So I moved over recently to the Code Sourcery - or tried. I can compile a simple: main(){while(1){}} program , etc. But when I try to move and compile my Atollic Projects, they do not compile. Simply: make -k all - with no file outputs, warnings, errors, etc. I have been using Eclipse WinArm for Atmel for years. I followed most specs that I could find - on installing Code Sourcery on Eclipse, - but with no result. Is Code Sourcery supposed to work like a Black Box ? Is there some Verbose parameter needed or something ? - Any Advice ? - Does anybody actually promote Code Sourcery ?2012-06-07 5:10 AM
As a matter of fact, even advanced technological capabilities are not necessarily accompanied by corresponding interhuman communication skills.
I see this discussion steering more into the irrational direction. So I remember that golden forum rule and not going to feed you anymore...2012-06-07 7:01 AM
.. Your FINALLY learning fm ..
So, can you keep off my other Topics also - until you learn to Respect this Golden Rule - and stop dumping Your Wasteful Negativity on all my posts ? I think others also reading this - don't want to hear you either - you provide nothing Useful - only rhetoric ... By the way - what don't You Understand about the Words : 'Go Away' - ? - You still don't get the idea ...2012-06-08 7:42 AM
That Golden rule is: ''don't feed the troll''.
2012-06-09 6:35 AM
''This is a Public Forum''
Indeed it is - so you don't get to choose who may contribute! Ever heard the expression, ''beggars can't be choosers''...?''if you can't provide Free Advice - then Go Away !'' I am happy to refund double the price you paid for my advice...
2012-06-09 6:42 AM
''ARE YOU A SALESMAN for Code Sourcery ?''
Just for the record, no - I'm not. Why do you find it an insult when someone simply points out to you that support options are available?
