2015-02-08 10:29 AM
How to make IP-Phone?, Its Main question.
I have some experiences on audio broadcasting with STM32 (UDP+RTP+[aLaw-uLaw]).I don`t know how to complete it to make a IP-Phone.I know SIP stack is needed too. but I don`t know how to implement this and how it`s work!2015-02-17 12:22 PM
I would recommend using re+rem+baresip. It is single-threaded in default configuration. You would need some kind of select() in your IP stack. I suspect it would also require stripping any non-essential functionality (debug logs, ICE, TCP transport, codecs beside G.711a/u, resampling, AEC, subscriptions) to be able to fit in memory. Video calls are also out of the question. Still, some SIP phones used '51 core for signalization + DSP.
My second choice would be pjsip - modular, neatly organized code but more complicated overall.2015-03-18 4:36 AM
thanks a lot.
Can you explain more?We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
