2021-08-13 5:04 AM
@Exmple:
:020000041FFFDC
:01F800000007
:020000041FFFDC
:01F80200FF06
:020000041FFFDC
:01F80400FF04
:020000041FFFDC
:01F80600FF02
:020000041FFFDC
:01F80800FF00
:020000041FFFDC
:01F80A00FFFE
:020000041FFFDC
:01F80C00FFFC
:020000041FFFDC
:01F80E00FFFA
:00000001FF
I was able to do the same in F series with the help of STVP tool, but in G0 series it is not possible.
2021-08-13 6:06 AM
Which STM32G0xx part specifically
I think the G0 have the Option Bytes at 0x1FFF7800 rather than the 0x1FFFF800 range this HEX data shows for the F0 series, total 16-bytes
It might be possible to array similar records for the G0 series.
Typically an erase, and rewrite all type operation, right?
2021-08-13 1:35 PM
Cubeprogrammer supports this?
2021-08-13 2:00 PM
Not sure, not using G0 here, but Keil typically has a "Flash Algorithm" for the option byte memory when programming the devices.
