2017-03-01 6:17 AM
Does stm32f429zi support usb in hs mode? i found that PB 14 is required by USB-HS but on that pin red led is connected.
Thanks for support.
2017-03-02 6:42 AM
Hi
Doe.Joe
,Since you need this pin for USB HS transfers,please follow the steps below:
1. Configure the PB13 as ''Reset State''.
2. Configure the External Phy depending on your needs (OTG/Dual_Role_Device, Host_Only, Device_Only).
Khouloud.
2017-03-02 6:42 AM
Hi
Doe.Joe
Khouloud.
2017-03-02 9:26 AM
Thank you
garsi.khouloud
!2017-03-03 2:38 AM
You are welcome
If you have further questions, do not hesitate to post them in our forum.
Khouloud.
