2021-10-12 1:38 PM
I am using an STM32H735G-DK board to do my tests. My goal is to toggle a LED on PC2 every time I wake up the MPU when I put PG5 to ground. Once the LED is toggled, I want the MPU to go to the lowest possible power consumption. Does anyone have an example (ideally with HAL libraries if possible)?
2021-11-01 4:10 AM
Hi @BenBel ,
The article PWR feature overview explains the various low power modes and how to use them in order to reduce power consumption.
You can also have a look to the product datasheet to know more about expected power consumption depending on the configuration you selected.
Another option is the examples available in STM32CubeH7 package and ready to use for a given scenario. Then it is up to you to update the example to meet your exact requirement.
-Amel
2021-11-01 4:52 AM
Hi Amel,
The article "PWR feature overview" sounds greate. Thank you very much!
