2020-12-02 11:41 PM
I have a Demo application based on the Audio Playback and record example program . This example defaults to using the onboard digital mics. I need to use the analog mic/CN6 Line in (blue) jack . I made changes to use the INPUT_DEVICE_ANALOG_MIC.
The application does not receive any audio events. Is there something else that needs to be reconfigured to support the analog mic?
If Anybody have solution about this Problem.Requested to reply faster.
