2020-12-04 10:57 PM
2020-12-05 2:15 AM
The exact answer depends on many many factors. This has been discussed here many times - search.
The best you can do is an experiment - set up an EXTI interrupt, toggle a pin in it, and observe the delay between input and output signal using oscilloscope/logic analyzer. Come back to discuss results. Don't forget to tell us details of your setup.
2020-12-05 3:05 AM
+1
You may also start reading a book. Joseph Yiu "The Definitive Guide..." comes to my mind.
2020-12-05 6:27 AM
The others are correct, but generally in the tens of cycles.
