2017-12-04 12:23 PM
The data sheet says there is no FMC on STM32F446RE. Is that means there is no chance to connect external RAM with STM32F446RE?
#stm-32 #external-ram #stm32f446re2017-12-11 11:32 PM
While the datasheet indeed says that, it's more that you simply don't have enough FMC-connected pins on the 64-pin package to make any reasonable connection.
You still can connect a SRAM and simply manually 'bit-bang' the read and write signals. Performance of course will be slow. SDRAM might be possible with a serious amount of hacking, but not practical at all.
There are also serially-connectible (SPI) SRAMs, e.g. from Microchip and ONSemi; again there is surely a need for some programming and some performance loss.
