2026-05-05 5:04 AM - last edited on 2026-05-08 1:59 AM by FBL
Hello all,
Split from this thread:
I'm using an STM32U5G9 and I need to read files from a USB stick.
I don't want to use ThreadX because I have to keep this application small.
How can I achieve this if UsbX and FileX are supposed to be used only with ThreadX and not in standalone mode?
Thanks for your help.
Best regards,
Julien
2026-05-05 8:04 AM
My original question was: how can I use USBX and FileX to read files from a USB stick (host mode) in standalone mode (so without ThreadX)?
It does not seem to work properly. I tried using the old ST USB stack with FatFS (https://github.com/STMicroelectronics/stm32u5-classic-coremw-apps) instead, and now everything seems to work fine.
Best regards,
Julien
2026-05-05 7:58 AM - edited 2026-05-08 2:04 AM
Hi @JulInnovel
USBX Host MSC standalone operation is not supported with FileX due to a dependency that requires the ThreadX context. When USBX Host is used in standalone mode, FileX cannot be supported, as enforced by a conditional definition in ux_host_class_storage.h that disables FileX support in standalone mode.
2026-05-05 8:04 AM
Best regards,
Julien
