2020-12-21 7:54 AM
I watched many examples on other boards, but they are always using I2S so I couldn't transposate to my case (SAI).
For now, I just would like to connect inputs (Jack IN1 or mems microphone IN2) to the output to understand how it works (maybe first via polling, then using DMA).
My final goal will be to use the acousticEC library, with the microphone input as voice signal, jack input as far end signal, and send the computed signal to the jack output. (Only left channel for the moment).
