2018-08-18 2:15 AM
I need a good tutorial how to start. It is first time for me to setup this SW.
I have used Stm32f429 before with Keil uVision5.
I don't know which SW required for my first model.
I have setup waijung17_03a and it is appeared as a Simulink library.
Thanks in advance
2018-08-18 6:21 PM
You start by deciding all your required functions:
then you use the Cube to set all those functions to pins..
then you use Kicad to make the PCB,
then you use an IDE to develop your code.
the easiest start is using the Provided software examples.
In the cube you can select an EVAL board.
