2021-04-24 11:11 AM
Erasing memory corresponding to segment 0:
Erasing internal memory sectors [0 4]
Error: failed to erase memory
Encountered Error when opening C:\ST\STM32CubeIDE_1.6.0\STM32CubeIDE\plugins\com.st.stm32cube.ide.mcu.externaltools.cubeprogrammer.win32_1.6.0.202101291314\tools\bin\STM32_Programmer_CLI.exe
Error in STM32CubeProgrammer
Debugger connection lost.
Shutting down...
What i do? Where i do mistakes? Where i get exact External Loader file for STM32F746IGT MCU
Thank you
2021-04-24 12:40 PM
Perhaps you can get more verbose and specific error information?
Run STM32 Cube Programmer independently, set the verbose level higher and test and evaluate read, erase, write, etc.
What exactly is your "custom" hardware configuration?
Have you done any basic bring-up testing of the QSPI memory to know if your implementation even works?
Can you read the JEDEC ID from the Winbond Memory? How about read some blocks in the 1, 2 and 4-bit modes?
There isn't an "exact" loader for the STM32F746IGT MCU, it's more about the F7 MCU and how you've wired the QSPI memory, and if it's functional.
Perhaps find the QSPI BSP code for the DISCO boards, and modify that to suit.
