2013-03-19 2:40 AM
I want to display 2 parameters(ID and BD) value on seven segment display. The values will be dynamically changed, so every time I want to write these 2 byte of values on FLASH memory and every power ON or System Reset, I want to Read that values from Flash Memory. Before writing any values if i read the Flash memory, I'm getting some garbage values. After erasing and writing 2 bytes of values to Flash memory, I am not able to read that again. Can anybody help me.... Thanks Selva. #flash-programming #flash-erasing-programming2013-03-21 1:20 AM
2013-03-21 1:26 AM
Thanks for all your response....I got the solution.
Actually I'm using Flash memory of 128KB, and the flash region is 0x08000000 - 0x0801FFFFWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
