2023-03-18 4:10 AM
i found an error in the Datasheet DS12712 Rev 4 of the STM32G473 Controller.
Can someone clarify please what will be correct:
In Chapter 4.11 - "Alternate functions" it tells, that PA10 has an alternate funktion AF2 for I2C3_SCL
But in Chapter 4.10 - "Pin definition" the I2C3_SCL is not listet for pin PA10 in the Alternate functions column.
So will the I2C3_SCL be available at PA10 or not?
2023-03-21 1:37 AM
Hello @Moritz ,
A new DS revision will be published as soon.
I will get back to you when the issue is fixed.
Thanks,
Foued
2023-03-18 4:51 AM
2023-03-21 1:37 AM
Hello @Moritz ,
Thanks,
Foued
