2018-02-24 10:35 PM
The currently posted document does not address the Z-step part, see pg 1899
This document is from Nov 2017, the A and Z steps are discussed in the Oct 2016 errata, along with a reference to RM0410 for details.
http://www.st.com/resource/en/reference_manual/dm00224583.pdf
http://www.st.com/resource/en/errata_sheet/dm00257543.pdf
http://www.st.com/en/microcontrollers/stm32f769ni.html
2018-02-26 9:19 AM
Also inconsistent naming of RCC_DCKCFGR1 as RCC_DCKFGR1 (pg 152 both names used in notes 2 and 3)
pg 210 uses the wrong naming, and in a dozen or so places in doc, HAL sources refer to
RCC_DCKCFGR1 which makes the most sense.
Makes searching and cross-referencing with in document annoying.
Also DCKCFGR2 used instead of RCC_DCKCFGR2 on pg 212, RCC_xx used consistently for other RCC registers and also in table of registers on pg 215-217
2018-02-26 9:19 AM
2018-02-27 8:22 AM
Hello
Turvey.Clive.002
,I confirm the missingaboutthe Revision Z and the wrong names that you mentioned.
Your feedback has been reported internally to update the related reference manuals in coming release.
Thanks andBest Regards,
Imen
2018-05-15 5:19 PM
Thanks, I see the new manual is posted.
