2019-06-10 2:39 AM
Hello everybody,
I have some problems with Dfuse Demo recently.
No changes in my device hardware.
In 2 PCs using Win10, Dfuse stopped work.
In other PCs using Win7 continue working correctly.
Have some tips for me?
Thanks in advance
Diego
2019-06-30 8:46 AM
Look at release schedules and dates.
STM32 Cube Programmer replaces
ST-LINK Utilities
Flash Demonstrator
DfuSe Demo
>>is this the official position of ST ?
I've been here 12+ years, I can read the tea leaves for myself. I'm sure if you dig through posts from ST staff you'll find the deprioritization of the older tools.
2019-06-29 10:01 AM
Hi Diego,
Same problem here - all my customers are affected by this one.
For development we can work around by using dfu-util but we are expecting someone from ST to come back with a fix (workaround)
Aurelian
2019-06-29 10:55 AM
The tool is deprecated, use the STM32 Cube Programmer, supports USB/DFU connectivity
https://www.st.com/en/development-tools/stm32cubeprog.html
2019-06-30 4:20 AM
is marked active on the ST.com website -
why do say is deprecated? is this the official position of ST ?
Aurelian
2019-06-30 8:46 AM
ST-LINK Utilities
Flash Demonstrator
DfuSe Demo
2019-07-02 4:47 AM
I solved using STM32 Cube Programmer instead. It's the only solution.
Cube Programmer is the newer tool and is better than Dfuse.
Thanks to Clive Two.Zero
best regards
2020-07-07 8:13 AM
How to you flash a dfu file to a device. STM32 Cube Programmer does not see it as a file so how is that a valid replacement for dfuse?
2020-07-07 8:27 AM
I started to use STM32 Cube Programmer for flashing .Hex files one year ago. I think it's the best way to program STM32 devices.
So IIt s a long time I don't use .dfu files.
Best regards
2020-07-07 8:29 AM
This doesn't help me because the firmware from the company I am working with only creates DFU's.
2020-07-07 8:51 AM
There is the possibility to convert DFU to BIN or HEX using "DFU file manager".
You can find this utility in STSW-STM32080 packet, linked below.
