2018-10-24 1:29 PM
When I start a debug session, the program start immediately instead of pausing, and the cursor is not at main() but at an odd spot in assembly. Using system workbench and a nucleo as a programmer. this is a custom target board running an STM32f091. What can cause this?
2018-10-24 1:43 PM
Code has not be downloaded properly. Break-points not set properly.
Try using pro-tools like Keil, should be a free license for STM32 CM0 parts.
2018-10-24 5:40 PM
So after much messing it is now mostly starting okay but I zm not getting timer interrupts. They work in run mode but not in debug. i checked the timer and it seems to be counting. wierd.
